Yep Components Podio Dropper Seatpost w/Remote
$645.00
Article number: 016-03-01
Discover the PODIO, YEP Components' new carbon dropper post with 80mm and 120mm travel options. The 120 mm seatpost offers adjustability with an included bushing spacer system for tailored travel. Both feature an improved bushing system for durability and smooth operation. The patented no-gas cartridge allows for easy servicing, and the carbon tube can be cut for fit and weight optimization. Starting at 325g, the PODIO is a pinnacle of lightweight, adjustable dropper posts, showcasing YEP's commitment to innovation and rider-centric design.
The Yep Components dropper seatpost offers customizable travel between 100mm and 120mm, adjustable with the included spacers. By cutting these spacers, you can achieve any desired travel length within this range. The package comes with two spacers, but additional spacers can be purchased for even more fine-tuning options, ensuring the perfect fit for your ride.
Dropper Post
 Travel 80 mm 120 mm
 Weight ~326g (30.9 mm) ~381g (31.6 mm)
 Length 290 mm
  115 mm trimmable 75 mm trimmable
 Seatpost Offset
 Routing Internal
 Min / Max Insert 100 mm / 290 mm
 Rail Compatibility 7 x 7 / 7 x 9 / 7 x 10
 Material Seatpost Internals
  Carbon Aluminum
Remote Lever
 Weight ~26.5g
 Material Alloy
