Woodman SL Ring Headset Spacers
Article number: | 012-06-04 |
Woodman Components is responsible for creating some extremely visually striking parts for nearly every application on the bike, in a plethora of colors. These are ideal for the cyclist looking to perfectly color tune their current build with vibrant bits of color. The SL Ring headset spacers are an excellent example of the tasteful color palette available from Woodman Components. CNC machined from 6061 aluminum for weight savings, and available in standard 5 and 10 mm stack heights, the SL Ring is perfect for dialing in your ideal fit.
Weight, 5mm | 4 grams |
Weight, 10mm | 8 grams |
Material | 6061 aluminum |
