Woodman SL Plus Seatpost
$60.00
WOODman Components is a well known company whose roots began over 10 years ago, setting out to produce an array of quality parts for any build that are sure to withstand the daily abuse of both mountain and road riding. Among the plethora of well crafted components is the SL Plus seatpost. Produced from T6 aluminum tubes, featuring 6061 aluminum alloy cradles with CrMo bolts, the SL Plus is the ideal post for the budget minded cyclist who still desires low weight and reliability. Designed to utilize a wider-than-average contact area for the bottom cradle of the seatpost, essentially ensuring a sturdy platform for each rider’s weight, while simultaneously increasing power transfer through the post. Performance aside, the most obvious attribute of the SL Plus post is the visually striking anodization available in nearly every color, perfect for color tuning your next build.
MaterialT6 aluminum
Offset0 mm
Max Torque5 Nm
Rail Compatibilityround
ovalized
Minimum Insertion111 mm
Weights
27.2mm x 350mm172 grams
27.2mm x 400mm197 grams
31.6mm x 350mm217.5 grams
Straight Post
Blue
Gold
Orange
Pewter
Pink
Red
Titan
Size:
350mm
Size:
400mm
Diameter:
27.2mm
Diameter:
31.6mm
Aluminum
