Woodman IT Zero Setback Integrated Seat Mast
$120.00
Article number: 012-03-03
Each Woodman IT series ISP head begins life as a single billet of aluminum, and is precision machined into the completed product. Equipped with high grade titanium hardware, the Woodman IT is among the lightest options available.
Precision-crafted from 6061 T6 aluminum, the Woodman IT Zero seatpost head features exacting tolerances and titanium hardware, making it a lightweight ISP solution. Its clamp fits 7 x 7 mm to 7 x 10 mm rails, with a 10 mm adjustment range and a 5 Nm torque rating. The 0mm offset promotes an aggressive riding position, requiring a 40 mm minimum insertion.
INSTALLATION
The IT features a cradle-and-yoke design that is compatible with metal or carbon rails in either round or ovalized design. The forward yoke bolt requires a 5.5 mm box end wrench, which is included along with installation instructions.
 Weight ~89g
 Length 60 mm
 Stack Height 17 mm
