The Deathgrip SL seatpost collar is an elegant, simple option for securing your seatpost. These seatpost collars are machined from lightweight and strong 6061 T6 aluminum, polished and bright anodized in a variety of hues to match just about any build aesthetic. Each collar is fitted with a CNC machined titanium bolt for further weight reduction and corrosion resistance.
Compared to the Deathgrip TCSL, this SL version has a lower height for frames with minimal seat collar interface. For best results, choose the SL for aluminum, steel, and titanium frames; the TCSL is recommended for carbon frames for extra clamping strength and increased clamping load distribution.
Material | 6061 T6 aluminum |
Hardware | titanium |
Weights | |
31.8mm | 11 grams |
34.9mm | 12 grams |
