Woodman Deathgrip SL Seatpost Collar
Article number: | 012-03-02 |
The Deathgrip SL seatpost collars are machined from lightweight and strong 6061 T6 aluminum, polished and bright anodized in a variety of hues to match just about any build aesthetic. Each collar is fitted with a CNC machined titanium bolt for further weight reduction and corrosion resistance.
Compared to the Deathgrip TCSL, this SL version has a lower height for frames with minimal seat collar interface. For best results, choose the SL for aluminum, steel, and titanium frames; the TCSL is recommended for carbon frames for extra clamping strength and increased clamping load distribution.
31.8 mm | 34.9 mm | |
Weight | ~10g | ~11g |
Clamp Material | CNC-machined 6061 T6 Aluminum | |
Hardware | Titanium | |
Clamp Height | 9 mm |
