Woodman Carbo EL Seatpost
$180.00
WOODman components has been designing and manufacturing quality parts for over 10 years. By doing all product design and testing in-house, they have established themselves as producers of components that fit nearly any build type, while being affordable, reliable, and lightweight. By testing their own products much further that typical European safety standards, they can guarantee that each component will withstand the rigors of the typical mountain and road ride. The Carbo EL seatpost is an excellent example of WOODman’s manufacturing and design prowess. Similar to the standard EL seatpost, the Carbo EL differs only in the materials used. Utilizing the same ultralight guts and titanium hardware, the Carbo EL sheds further weight by replacing the typical aluminum main tube with a full carbon variation. Perfect for the gram conscious cyclist on a budget, the Carbo EL is sure to add an aesthetically pleasing touch to your next build.
Each WOODman Carbo EL seatpost has a minimum and maximum insertion range, therefore it is extremely important that it never be cut or trimmed. Cutting any length off of your Carbo EL can result in unsafe riding conditions. Please be sure to use a proper torque wrench when installing your WOODman Carbo EL, and follow all torque ratings.
Seatpost LengthInsertion Range
250mm 130-180mm
350mm 170-260mm
400mm 220-300mm
Materialcarbon
Offset0 mm
Hardwaretitanium
Max Torque3 Nm
Rail Compatibilityround
ovalized
Weights
27.2 x 250mm101 grams
27.2 x 350mm122.5 grams
27.2 x 400mm128.5 grams
30.9 x 250mm110.5 grams
30.9 x 350mm136 grams
30.9 x 400mm144 grams
31.6 x 250mm111.5 grams
31.6 x 350mm146 grams
31.6 x 400mm149 grams
