Woodman Carbo DX Seatpost
Article number: | 012-04-03 |
The Carbo DX seatpost is certainly no exception to this tradition. Similar to the alloy DX seatpost, the Carbo DX is an intelligently designed, lightweight setback seatpost. With 25mm of offset, this seatpost is perfect for cyclists who desire more adjustability for the ideal fit. Utilizing CNC-machined titanium fasteners, ultralight rail clamp hardware, and an internally relieved carbon main tube, the Carbo DX seatpost is an excellent option in an offset-style seatpost.
INSTALLATION
Each Woodman Carbo DX seatpost has a minimum and maximum insertion range, therefore it is extremely important that it never be cut or trimmed. Cutting any length off of your Carbo DX can result in unsafe riding conditions. Please be sure to use a proper torque wrench when installing your Woodman Carbo DX, and follow all torque ratings.
Weight | |||
Length | 250 mm | 350 mm | 400 mm |
27.2 mm | ~124g | ~145g | ~155g |
30.9 mm | ~136g | ~158g | ~169g |
31.6 mm | ~137g | ~162g | ~173g |
Minimum Insertion | 65 mm | 90 mm | 95 mm |
Carbon Weave | 3k Weave / Matte or Gloss |
