Woodman Capsule Extrem
$30.00
WOOdman Components' Capsule Extrem is an innovative, simple-to-use headset preload assembly built for more aggressive riding styles where headset security is paramount. The Capsule Extrem eschews the traditional steerer plug in favor of a more robust sandwich design for headset adjustment and steerer tube reinforcement. Intended for suspension forks, but compatible with any open bottom steerer tubes, this preload assembly features an adjustable length with clearly marked graduations for quick and easy sizing. The Casule Extreme will accommodate total steerer tube lengths from 175-270 mm. As an added bonus, the Capsule's underside is equipped with female M5 thread as an option for mounting a front fender.
The Capsule Extrem is available in two diameters; one for traditional 1-1/8" steerer tubes, and another for oversize 1-1/2" steerer tubes. It is possible to combine the upper and lower halves of each size to accommodate the most common size 1-1/8" to 1-1/2" tapered steerer tube.
Weight, 1-1/8"75 grams
Weight, 1-1/2"133 grams
Material6061 T6 aluminum
Adjustment Range175-270 mm
