Wolf Tooth Components are considered one of the pioneering companies when it comes to 1x chainrings. They were the first to market with cyclocross 1x specific chainrings, seizing the opportunity to exhibit their Drop-Stop tooth technology on the rougher mixed-terrain found in cross racing. Countless hours of design, prototyping, and testing have gone into their patent-pending chainring technology, resulting in some of the best performing and longest lasting narrow/wide rings available.
Now available for asymmetric 4-Bolt 110 BCD Shimano cranksets, these beautifully machined 7075 T-6 aluminum rings are optimized for your 1x Shimano Gravel/CX/Road drivetrain. One of the most important design aspects of these rings, the Drop-Stop tooth profile, features wide teeth that are asymmetrically shaped. The right side of the tooth, which transmits drive forces, is made as wide as possible to maximize surface contact between the chain and ring, effectively minimizing tooth wear by spreading the load over a larger area. The left side of the tooth doesn’t transmit any load, it mainly helps guide the chain as it meshes with the ring. As wear is not a concern on this side, Wolf Tooth has designed the left side of the tooth to be narrower than the roller pin of the chain, effectively reducing friction while simultaneously creating a mud-shedding channel. Beyond the innovative tooth-profile, close attention was paid in designing these rings with the perfect amount of offset; designed to be mounted in the big ring position, the inward offset yields a perfect chainline (47.5mm). These rings are feature an anodized black finish with white logos and are designed and manufactured in the USA.
Compatibility
Color | Black |
Material | 7075-T6 Aluminum |
Crank Compatibility | Shimano Asymmetric 4-Bolt 110 BCD |
Drivetrain Compatibility | Dura Ace 9000 Ultegra 6800 105 5800 Tiagra 4700 Tiagra 4703 |
Weight | |
40T | 70g |
