White Industries XMR Disc Rear Hub
$337.00
With nearly 4 decades under their belt White Industries has honed their component lines to perfection. Much like their brilliant and simple design each product has been polished over the years to pure excellence. Manufacturing every single product in their Northern California warehouse White industries represents one of the few companies dedicated to maintaining quality and American made reliability. From humble beginnings to the highly successful company they are today, White Industries owes their success to a passion for cycling and the craftsmanship they put into every single part they make.
With this latest iteration of their ISO disc hub White Industries has hit it out of the park. Truly one of the most finely finished hubs available today the XMR represents the quality and durability that you expect from a product that is made in the USA. While not in the featherweight category of bicycle hubs the XMRs make up for it in durability and performance. The 3 pawl 48 point engagement system is snappy and offers solid engagement for the most technical situations you can find. The large widely spaced flanges provide a remarkably stiff final build ideal for mountain, cyclocross, or road disc applications. With multiple freehub body options available these hubs can be adapted to fit any build Shimano, Sram, and even Campagnolo freehub bodies are made for this hub. Compatible with 9, 10, and 11 speed drivetrains this hub is a swiss army knife in your pocket that can quickly be adapted to fit virtually any build. Offered in a plethora of drilling patterns and colors, snag a pair of these hubs and see just what Made in the USA craftsmanship means.
We are currently only stocking the black anodized version of these hubs. If you would like a different set please contact us to make arrangements.
Bearing SizeShimano 6902 (2), 3802W (1)
Campagnolo 6902 (2), 3802W (2)
Hub Shell Materialaluminum
Wheel Building Dimensions
Flange Diameter, Left60 mm
Flange Diameter, Right60 mm
Center to Left Flange33 mm
Center to Right Flange19.5 mm
Weight298 grams
Rear Disc Brake Hubs
Fits:
28h
Style:
Mountain
Style:
Road Disc
Diameter:
TA 12x142
Freehub Body:
Shimano Mountain
Freehub Body:
Shimano Road 11
