White Industries T11 Rear Road Hub
$403.10
The T11 is White Industries rim brake (non-disc) road hub and is the perfect choice for road builds.  Made in our shop from U.S. sourced 6061-T6 aluminum, they’re available in a range of colors, drillings and driver styles.
  • U.S. made 6061-T6 aluminum
  • Enduro bearings
  • Cassette spacer included only on XDR freehub bodies
  • Available separately for Shimano HG11 (part# SPACER11)
Specs
  • 252g
  • 20H, 24H, 28H, 32H, 36H drillings
  • Axles: 130mm x 10mm QR
Bearings
  • All Enduro ABEC 5 except 3802W (ABEC 3)
 Driver Style
Left hub shell bearing Right hub shell bearing Inner driver bearing
Outer driver bearing
 Shimano   Hyperglide 11   speed
61902-SRS 61902-SRS 3802W LLB
61902-SRS
 Shimano Micro   Spline
3802W LLB
 SRAM XD/XDR
3802W LLB
 Campy 11 speed
61902-SRS 61902-SRS 3802W LLB 3802W LLB
Wheelbuilding specs
Spoke Hole Diameter : 2.3mm
 Left flange   diameter
Right flange diameter Center to left flange
Center to right flange
 40.5mm
55mm 35mm 18mm
