White Industries CLD Rear Centerlock Hub
Article number: | 012-01-03 |
White Industries CLD (Center Lock Disc) hubs are designed around the Center Lock splined rotor mounting interface as opposed to the 6-bolt mounting standard. Made from U.S. sourced 6061-T6 aluminum, they’re available in a range of drillings, colors, and axle configurations.
- U.S. made 6061-T6 aluminum
- Enduro bearings
- 6/4 titanium driver
- 3-pawl, 48 point (7.5 degree) engagement
- Compatible with Center Lock style rotors
- Rotor lockrings not included
- Rotor lockring compatibility
- Internally splined lockring such as Shimano SM-RT81
- Cassette spacer included only on XDR freehub bodies
- Available separately for Shimano HG11 (part# SPACER11)
Specs
- 256g
- Drillings: 24, 28, 32, 36
- Axles:
- 12mm x 142mm Thru
- 10mm x 135mm QR
Bearings
- All Enduro ABEC 5 except 3802W (ABEC 3)
Driver Style |
Left hub shell bearing | Right hub shell bearing | Inner driver bearing |
Outer driver bearing |
Shimano Hyperglide 11 speed |
61902-SRS | 61902-SRS | 3802W LLB |
61902-SRS |
Shimano Micro Spline |
3802W LLB |
SRAM XD/XDR |
3802W LLB |
Campy 11 speed |
3802W LLB |
Campy N3W/EKAR 13 speed |
3802W LLB |
Wheelbuilding specs
- Spoke hole diameter
- 2.6mm
Left Flange Diameter | 45mm |
Right Flange Diameter | 55mm |
Center To Left Flange | 33mm |
Center To Right Flange | 19mm |
