White Industries CLD Front Centerlock Hub
$184.00
Article number: 012-01-03
White Industries CLD (Center Lock Disc) hubs are designed around the Center Lock splined rotor mounting interface as opposed to the 6-bolt mounting standard. Made from U.S. sourced 6061-T6 aluminum, they’re available in a range of drillings, colors, and axle configurations.
  • U.S. made 6061-T6 aluminum
  • Enduro bearings
  • Compatible with Center Lock style rotors
  • Rotor lockrings not included
  • Rotor lockring compatibility
    • Internally splined lockring such as Shimano SM-RT81
    • Externally splined lockring such as Shimano SM-HB20 or HB-M8010
Specs
  • 145g
  • Drillings: 24, 28, 32, 36
  • Axles:
    • 15mm Thru (works with removable QR plugs)
    • 12mm x 100mm Thru
    • 9mm x 100mm QR (plugs remove to convert to 15 Thru)
Bearings
  • Two Enduro ABEC 5 17287-2rs bearings
Wheelbuilding specs
  • Spoke hole diameter
    • 2.6mm
Left Flange Diameter 45mm
Right Flange Diameter 45mm
Center To Left Flange 20.5mm
Center To Right FLange 34.5mm
