Wend Waxworks Wax-On Chain Lubricant - Original
Article number: | 018-01-02 |
5 pack of .5oz pocket waxes
Keep them in your pocket for a quick lube-up mid-ride!
***KEEP LID ON TIGHT TO ENSURE PRODUCT REMAINS FRESH
Application is easy, just rub it onto your chain and work it into the rollers using your finger.
1st at Race Across America
1st at Gravel Worlds
WEND Wax‐On is the first ever “rub‐on”, wax based, chain lubricant. Wax‐On not only keeps your chain clean, its friction reducing additives make for an extremely quiet and efficient drive-train. Wax‐On is quiet, quick, and clean. It is no secret that the most efficient chain lubrication method to date is immersing a chain into a vat of molten paraffin. However, this method is time consuming, temporary, and dangerous. WEND Waxworks set out to create a lube that would perform equal to or better than hot waxing and that would be easy to apply. After two years of development, the R&D at WEND has come up with Wax‐On. Wax‐On is a sophisticated paraffin based formula that includes proprietary friction reducers as well as proven lubricants such as Zinc and Teflon. The application is a cinch as the user simply rubs the
wax onto the chains rollers, resulting in a race ready chain in seconds. Overall user satisfaction is high due to the ease of use, product cleanliness, and lubrication performance.
