Wahoo Speedplay PowrLink
$649.99
Article number: 011-04-02
Experience top-tier cycling data with Wahoo PowrLink Zero, built on the advanced Speedplay platform. This power meter pedal ensures reliable and precise power metrics, offering cyclists a thorough insight into their performance. Achieve breakthrough results with claimed +/- 1% accuracy, oval chain ring compatibility, optional left/right balance, and a 75-hour rechargeable run time. Wahoo's PowrLink stands out with best-in-class features: optimal stack height, weight, aerodynamics, cornering clearance, knee-friendly adjustability, and customizable float. For a pedal-based power meter system that's tough to surpass, choose Wahoo.
  ZERO Pedal (Dual) Left Side (Single)
 Weight ~276 grams ~250 grams
 Stack Height 13mm (3-hole) 13mm (3-hole)
 Body Material Grivory GV-6H Grivory GV-6H
 Spindle Material Stainless Steel Stainless Steel
 Q Factor 55mm 55mm
 Cornering Clearance 39° 39°
 Max Rider Weight 250lbs/113kg 250lbs/113kg
 Cleats Included Standard Tension Standard Tension
 Release Angle 0° to 15° 0° to 15°
 Walkable Cleat Yes (Adapter Included) Yes (Adapter Included)
 Left/Right Balance Yes No
