Wahoo / Speedplay Pedals
Article number: | 017-04-01 |
Availability: | In stock (4) |
Experience the reinvention of the world's only dual-sided clipless pedal, a collaboration between Speedplay and Wahoo. The re-engineered spindle and pedal body elevate Speedplay pedals. Renowned for unparalleled adjustability, customizable cleat position and float for optimal power output and knee comfort. Wahoo's pedal system excels in stack height, weight, aerodynamics, and cornering clearance, setting a high standard.
NANO | AERO | ZERO | COMP | |
Weight | ~168g | ~224g | ~222g | ~232g |
Stack Height | 11.5mm (3-hole) / 8.5mm (4-hole) | 11.5mm (3-hole) / 8.4mm (4-hole) | ||
Body Material | Carbon | Grivory GV-6H | Grivory GV-6H | Grivory GV-6H |
Spindle Material | Titanium | Stainless | Chromoly | |
Spindle Length | 53mm | 53mm | 53 / 56 / 59 / 65 | 53mm |
Cornering Clearance | 39° | 37° | 39° | 39° |
Max Rider Weight | 180lbs / 82kg | No Restriction | No Restriction | No Restriction |
Cleats Included | Standard Tension | Standard Tension | Easy Tension | Standard Tension |
Release Angle | 0° to 15° | 0° to 15° | 0° to 15° | 0° to 15° |
Walkable Cleat | Yes | Yes | Yes | Yes |
