U.S.E. Vybe Suspension Seatpost
$165.00
Article number: 004-02-01
Availability: In stock (2)
The Vybe is our latest generation suspension seatpost with 50mm of Active tuneable travel. It tames the trails increasing your power, endurance and comfort. The suspension of the Vybe reduces the effect of terrain on the body allowing energy to be concentrated on the pedals. Enabling consistent seated pedaling for increased power and comfort.  The Vybe features the SUMO clamp, the highly acclaimed, quick fitting, simple to adjust system designed to ensure the perfect saddle position (full range of saddle tilt available).  All suspension seatposts are fully serviceable, adjustable for rider weight and give many years of loyal service with comfort, recovery and performance benefits.
To achieve the optimum ride choose your spring option from soft, medium or hard according to your weight. There is also a 'Pre-Load Adjustment' screw at the bottom of the post allowing you to fine tune the post to give you the ultimate ride.
*Supplied with standard 7x7mm clamp. Other size clamps to fit oval carbon rails are available. Please see the saddle manufacturers measurement, if the rails are wrapped please check the measurements are still valid.
Weight ~400g
Length 400mm
Diameter 27.2mm
Material Aluminium
Setback 10mm
Finish UD Matt
Spring Rate Spring Colour Rider Weight - Lbs Rider Weight - Kgs
Soft Green 85 - 120 38 - 55
Medium Yellow 120 - 174 55 - 80
Hard Purple 174 - 225 80 - 100
