10% Off all ControlTech including the TiMania lineup of Titanium Components.
Tune Wassertrager 2.0 Carbon Bottle Cage
Sign Up For Our Newsletter
You're Signed Up!
Weight10.5 grams
Weight w/ Bolts12.5 grams
Compatibilitystandard ~75 mm bottles
Tune Wassertrager 2.0 Carbon Bottle Cage Bottle Cage $70.00 In Stock
Details
The Wässertrager 2.0 from renowned German bicycle component manufacturer, Tune, sets a new benchmark for lightweight and functional bottle cages. At a mere 10.5 grams, very little else comes close to the svelte weight of this finely crafted accessory. Most bottle cages use a flexible or expandable design and often add tabs or rubber grips to adequately secure their bottles. The Wässertrager 2.0 relies on precision craftsmanship and quality control to ensure that bottles are held tightly within its rigid carbon frame. As an added benefit, the smooth lines of the cages's carbon structure will provide lower wind drag for superior aerodynamics. Tune has the utmost confidence that bottles will not be ejected from these cages - they are recommended for all but the most aggressive downhill terrain.
A pair of lightweight 7075 M5 aluminum screws are included for mounting the cage to standard bottle cage bosses. Bottles are not included; a 500 ml bottle is displayed to show scale. Tune's cages are compatible with all standard diameter water bottles.
