10% Off all 3T Components!
Tune Spurtreu Stem Alignment Tool
Sign Up For Our Newsletter
You're Signed Up!
BatteriesLR44 (3, included)
Tune Spurtreu Stem Alignment Tool Spurtreu $95.00 In Stock
The Tune Spurtreu is a unique and well designed solution to a problem as old as bicycles themselves. Many of us find ourselves frustrated and at wits end when trying to perfectly align our bicycle’s stem with the front wheel. Often you may find yourself 10 miles into a ride only to notice that your handlebars are misaligned by a few millimeters, which is enough to drive even the most calm riders insane.
Basically, the Tune Spurtreu is a laser pointer that has been mounted inside a CNC machined aluminum frame that is designed in such a way that it naturally aligns itself to dead center between your bars and stem. Assuming your front wheel is dished correctly, the Spurtreu will cast a laser beam onto your front tire, making any alignment issues immediately obvious. Additionally, the Spurtreu is compatible with nearly any handlebar and stem combination.
The Spurtreu can easily find a place for itself in the toolbox of both professional shops, or the perfectionist home mechanic.
