Tune Energietrager
$21.60
Due to the absence of any elegant way to securely position your Shimano Di2 battery in your seatpost, Tune has masterfully created a simple solution to the common problem. The Energietrager from Tune is a straightforward aluminum and silicon compression wedge that can be installed on your internal seatpost battery in seconds. By utilizing a friction inducing silicon wedge, the battery is firmly held inside the seatpost, resulting in a clean aesthetic and peace of mind. Available in 2 sizes, size S is compatible with seatposts featuring a 26.8 - 27.6mm inner diameter, while size M is designed for 28 - 30mm inner diameter posts. Detailed installation instructions are included with each Energietrager.
Weight9.3 grams
Compatibility
Size S26.8 - 27.6mm inner diameter posts
Size M28 - 30mm inner diameter posts
Di2 Accessories
