Tune DC12 Rear 12mm Thru Axle
$138.00 $99.00
(You save $39.00)
With the DC12 thru axle, Tune brings their lightweight elegant skewer design to the stiff thru axle standard. The 12x142mm rear axle is a leap forward for rear suspension stiffness. By combining the skewer and axle into one solid piece with the wider 142mm spacing the drivetrain, hub, disc brake, and frame act more as one solid piece. Increasing stiffness during sprints and decreasing any chatter while braking. This keeps the rear wheel on the ground decreasing braking distance and keeping a smooth confidence inspiring line into any corner.
Frame Compatibility
The Scott version of the DC12 is compatible with most Scott mountain frames, as well as some Santa Cruz frames. The Syntace X12 thru axle is compatible with Cannondale and other manufacturers.
ModelInterfaceLengthThread PitchThread LengthWeight
Syntace X12Tapered159mm12x116.5mm36.8g
Material7075AL/Carbon (Lever)
Hub Compatibility12mm
Tool FittingQR
