Tripeak Delrin Derailleur Pulleys
$30.00
In the never ending chase of speed, friction in your drivetrain poses a real problem for every rider. Even with proper maintenance and lubrication there can still be excess drag caused by the derailleur pulleys.The Tripeak Delrin pulleys offer an easy and inexpensive upgrade from stock. Made from low friction delrin paired with a high quality steel bearing, these pulleys roll smoother than stock and make less noise than aluminum pulleys. Available in seven eye catching colors these pulleys give a bit of personality to your drivetrain.
When installing please note that the pulley with longer teeth is designed for the upper guide pulley position and the short toothed pulley in the tensioner position.
Weight 25 grams (Set)
Material Delrin
Bearing 626, steel cartridge
Compatibility 11 speed
