Tripeak Ceramic Delrin Derailleur Pulleys
Friction is the enemy of every rider. A properly maintained and lubricated drivetrain is essential to top performance, but there are a couple small improvements that can still be made. The Tripeak Ceramic Delrin pulleys offer the best resource for eliminating friction from your driveline. With a hybrid ceramic bearing and delrin body these pulleys allow the chain to glide through the derailleur effortlessly. The friction reducing properties of delrin make it the perfect material for this application, and the ceramic bearing produces far less friction than its steel counterpart. Ceramic bearings have proved to be a superb upgrade for cycling applications, and with these pulleys we can see why. Just spinning them in your fingers demonstrates the smoothness inherent in high quality bearings. When every second counts don’t let friction slow you down.
Please note that the pulley with longer teeth is intended for the upper position and the lower pulley is marked directionally.
Weight 24.5 grams (Set)
Material Delrin
Bearing Hybrid Ceramic
Compatibility 11 Speed
