Tioga Spyder Twin Tail 2 Saddle
Article number: | 018-02-01 |
While Tioga Spyder saddles certainly look striking, visual appeal was a completely secondary design consideration. Looking to create the most comfortable saddle yet, Tioga found that traditional foam padding would not lead them to success. The interlaced web design was chosen to flex and conform to the individual shape of every rider. Staying pliable and supportive, the Spyder acts as a mini "hammock" supporting riders evenly without high pressure points. Flexing and moving with the body over uneven surfaces the Spyder has a dual purpose, a seat as well as a mini shock absorber to alleviate impacts and fatigue from riding over rough terrain.
The TwinTail 2 provides unsurpassed comfort without compromise. The implementation of the split allows each half to act independently for maximum comfort on long rides. Tuned using the underneath structural braces for efficiency with a balance of flexibility, the TwinTail 2 is durable, lightweight, and comfortable. No matter what style of riding you choose the TwinTail 2 will have you focusing on the path ahead and not your behind. Firm yet flexible, light yet durable, stiff yet supple, the TwinTail 2 offers the perfect balance of comfort, performance, and weight. Ideal for mountain and road applications, the Spyder TwinTail 2 is our favorite for aggressive positions and all day rides.
Included with each saddle are silicone anti-slip pads that offer a small amount of cushion while keeping your sit bones securely on the sweet spot. Easy to install and remove the anti-slip pads offer riders an easy option for tuning their saddle to match their riding style.
Weight, Carbon Rails | 120 grams |
Weight, Titanium Rails | 180 grams |
Weight, CrMo Rails | 190 grams |
Shell Material | DualTech Carbonite (Impact resistant composite) |
Width | 135 mm |
Length | 275 mm |
Carbon Rail Diameter | 7x9 mm oval |
Use | Road, CX, Mountain |
