Tioga Spyder Outland Saddle
Article number: | 026-03-01 |
While Tioga Spyder saddles certainly look striking, visual appeal was a completely secondary design consideration. Looking to create the most comfortable saddle yet, Tioga found that traditional foam padding would not lead them to success. The interlaced web design was chosen to flex and conform to the individual shape of every rider. Staying pliable and supportive, the Spyder acts as a mini "hammock" supporting riders evenly without high pressure points. Flexing and moving with the body over uneven surfaces the Spyder has a dual purpose, a seat as well as a mini shock absorber to alleviate impacts and fatigue from riding over rough terrain.
Float over rough terrains seated on a flexile web cover that continually absorbs shock, keeping you suspended. An ingenious silicone anti-slip pad (removable) minimizes sliding to keep you seated on the sweet spots. The extraordinary Spyder Outland is performance and comfort in 180g.
Open frame with underside structural braces designed to control the rate and level of compression (limits excessive sag). The frame is seamlessly fused together with a more pliable, flexile webbed cover. The Spyder Outland meets all EN Safety Standards for saddles.
Weight, Titanium Rails | 180 grams |
Shell Material | DualTech Carbonite (Impact resistant composite) |
Width | 126 mm |
Length | 281 mm |
Carbon Rail Diameter | 7x9 mm oval |
Use | Road, CX, Mountain |
