THM Ulna Road Bar
Article number: | 014-05-02 |
The THM Ulna carbon handlebar exemplifies THM's expertise in design, testing, and production. Weighing just ~157 grams (42cm), it maintains stiffness with a proprietary internal structure. Its compact geometry includes a 119 mm drop, 77 mm reach, and 6° flare for precise handling. Features like internal Di2 wiring ports, housing grooves, and textured clamping surfaces ensure a clean look and secure attachment. The flat bar tops offer comfort, and the satin black finish with white logos highlights its refined aesthetics. Professional installation recommended. Not compatible with clip-ons.
INSTALLATION & ORDERING
The THM Ulnas are not compatible with aero extensions, use of which will void the warranty. We recommend that these handlebars be installed by a professional mechanic.
Width | 40cm | 42cm | 44cm |
C to C Hoods | 38 cm | 40 cm | 42 cm |
C to C Drops | 40 cm | 42 cm | 44 cm |
Weight | ~155g | ~158g | ~163g |
Reach | 77 mm | ||
Drop | 119 mm | ||
Flare | 6° | ||
Stem Clamp Diameter | 31.8 mm | ||
Material | Carbon Fiber | ||
Finish | Satin | ||
ICR Compatible | Yes (Internal Ports) | ||
Rider Weight Limit | 243 lbs (110 kg) |
