THM Tibia Carbon Road Stem
$549.00
After much anticipation, German manufacturer THM presents perhaps the finest bicycle stem ever produced: the Tibia. Elegantly manufactured from carbon fiber, the Tibia achieves impressively light finished weights due to its hollow construction and careful design. In their specific material choices and fabrication method, THM has created a stem that is not only lightweight; these stems are incredibly stiff, while providing a measure of high frequency damping to absorb road buzz and increase rider comfort. An intelligent combination of titanium, aluminum, and steel material in the stem's 100% replaceable hardware ensures that no gram is wasted and maximum safety is ensured. Each Tibia stem is given a lightly polished satin finish and fitted with an understated grey logo.
Weights
80mm80 grams
100mm85 grams
110mm88 grams
120mm91 grams
Angle-6°
Stack40mm
Handlebar Clamp Diameter31.8mm
Steerer Clamp Diameter28.6mm (1-1/8")
Stem and Faceplate Materialcarbon fiber
Hardwaresteel, aluminum, titanium
Maxium Bolt Torque4 Nm
Rider Weight Limit110 kg (242 lbs)
Recommended UseRoad
Stems
3K Matte
Size:
80mm
Size:
100mm
Size:
110mm
Size:
120mm
