THM Tibia Carbon Road Stem
$649.00
* Unit price: $599.00 /
Article number: 014-06-01
Following a thorough research, development, and testing process, German manufacturer THM presents perhaps the finest bicycle stem ever produced: the Tibia. Elegantly manufactured from carbon fiber, the Tibia achieves impressively light finished weights due to its hollow construction and careful design. In their specific material choices and fabrication method, THM has created a stem that is not merely a lightweight showpiece; these stems are incredibly stiff, while providing a measure of high frequency damping to absorb road buzz and increase rider comfort. An intelligent combination of titanium, aluminum, and steel material in the stem's 100% replaceable hardware ensures that no gram is wasted and maximum safety is ensured. Each Tibia stem is given a lightly polished satin finish and fitted with an understated grey logo.
Stem Length 80 mm 100 mm 110 mm 120 mm
Weight ~ 80g ~ 85g ~ 88g ~ 91g
Angle -6°
Stack 40 mm
Stem Clamp Diameter 31.8 mm
Stem and Faceplate Material Carbon Fiber
Hardware Steel, Aluminum, Titanium
Maximum Bolt Torque 4 Nm
Rider Weight Limit 243 lbs (110 kg)
Recommended Use Road only
