THM Frontale Handlebar / Stem Combo
Article number: | 30-05-02 |
The THM Frontale is a fully integrated carbon handlebar(Ulna) and stem(Tibia) combo engineered for aerodynamic superiority, ultra-light weight, and stiffness. Whether you're racing crits, climbing mountains, or shaving seconds in a time trial, the Frontale offers precise control and optimized positioning.
Designed with structural efficiency and reduced frontal area in mind, the original Frontale remains a favorite among performance-focused cyclists. For riders seeking even more aerodynamic refinement, we now also offer the THM Frontale Aero version, which features sleeker shaping and improved airflow management — ideal for time trials, triathlons, or flat-out speed setups.
INSTALLATION & ORDERING
The Ulna handlebar is not compatible with aero extensions, use of which will void the warranty. THM measures their handlebar widths at the drops, please keep this in mind when ordering.
Handlebar | 40cm | 42cm | 44cm |
C to C Hoods | 38 cm | 40 cm | 42 cm |
C to C Drops | 40 cm | 42 cm | 44 cm |
Reach | 77 mm | ||
Drop | 119 mm | ||
Flare | 6° | ||
Stem | 90 mm | 100 mm | 110 mm |
Angle | -6° | ||
Stack Height | 40 mm | ||
Stem Clamp Diameter | 31.8 mm | ||
Material | Carbon Fiber | ||
Finish | Matte | ||
Rider Weight Limit | 243 lbs (110 kg) |
