THM Frontale Aero Handlebar / Stem Combo
The THM Frontale Aero is the aerodynamic brother of the ever popular THM Frontale. These bars are highly customizable, clean, sleek, light weight(<250g (420x100)). Just like the standard Frontale, these bars come ICR equipped, with all of the appropriate entry and exit points for internal cable routing.
COMPUTER MOUNT
THM offers a proprietary computer & go pro combo mount for the Frontale Aero handlebars. Have a look at the 'Frontale Headmount' here.
ORDERING
These handlebars are made per order, so if you want to get your hands on a set then contact us, and we would love to help get your order started.
38cm | 40cm | 42cm | |
C to C Hoods | 34 cm | 36 cm | 38 cm |
C to C Drops | 38 cm | 40 cm | 42 cm |
Reach | 75 mm | ||
Drop | 127 mm | ||
Flare | 7° | ||
Stem | 100 mm | 110 mm | 120 mm |
Angle | -6° | ||
Stack Height | 38 mm | ||
Stem Clamp Diameter | 31.8 mm | ||
Material | Carbon Fiber | ||
Finish | Matte | ||
Rider Weight Limit | 243 lbs (110 kg) |
