$1,449.00
* Unit price: $1,350.00 /
Article number: 025-01-03
THM Fibula revolutionizes braking for wide rims, maintaining a decade of unmatched performance at half the weight of major brands. Utilizing resin transfer molding (RTM) enhances tolerance and strength-to-weight, with an eco-friendly approach. The composite return spring and adjustable cam adapt seamlessly to 19–30 mm rims, offering consistent modulation for diverse wheelsets and tires up to 25 mm wide. Optimized pull ratio for Shimano, SRAM, and Campagnolo levers, the pair weighs just 120 g, continuing Fibula's legacy as the lightest brake set.
 Weight ~120g w/o Pads (~61g Front / ~59g Rear)
Brake Pads Shimano standard brake pad inserts
 Compatible Brake   Levers All Rim brake cable pull levers
 Rim Width Up to 30 mm wide
 Rider Weight Limit 110 kg (243 lb)
