THM Clavicula SE Power Meter Crankset
Article number: | 26-02-00 |
THM's advanced full-carbon crank, featuring an integrated power meter and carbon axle, stands out due to its innovative design. Through meticulous analysis of load paths, THM has optimized its geometry and structure for exceptional stiffness in all directions, ensuring efficient power transmission.
Notably, THM takes pride in its patented carbon-to-carbon connection between the left-hand crank and axle, setting a new standard for the bicycle drivetrain. This design aligns the fibers of external and internal splines, minimizing wear and noise, while also reducing weight to an impressive 329g with the spider and power meter. The Clavicula SE redefines crank design and sets a new industry benchmark.
BCD | 110 mm | 130 mm |
Weight | ~320g | ~329g |
Spindle Diameter | 30 mm | |
Q-Factor | 148 mm | |
Chainline | 43.5 mm | |
Crank Lengths | 170 mm / 172.5 mm / 175 mm | |
Rider Weight Limit | 110kg (243 lbs) | |
Finish | 3k Twill - Matte or Gloss | |
Powermeter Information | ||
Sensor Position | Integrated into Spindle (measures left side) | |
Measures | Power / Cadence / Torque / Pedal Smoothness (Left) | |
Accuracy | +/- 2 % | |
Power Range | 0 W - 1999 W | |
Connectivity | ANT+ or Bluetooth compatible bike computer or smartphone | |
Manufacturer Module | SENSITIVUS Gauge | |
APP | Team ZWATT Power Meter | |
Firmware | Firmware updates via App | |
Battery | Integrated Rechargeable Li-ion Battery | |
Run Time | 150 hrs. | |
Waterproofing | IP 67* |
*100% protected against solid objects like dust and sand, and it has been tested to work for at least 30 minutes while under 15cm to 1m of water
