THM Clavicula SE Power Meter Crankset
$2,699.00
* Unit price: $2,295.00 /
Article number: 26-02-00
THM's advanced full-carbon crank, featuring an integrated power meter and carbon axle, stands out due to its innovative design. Through meticulous analysis of load paths, THM has optimized its geometry and structure for exceptional stiffness in all directions, ensuring efficient power transmission.
Notably, THM takes pride in its patented carbon-to-carbon connection between the left-hand crank and axle, setting a new standard for the bicycle drivetrain. This design aligns the fibers of external and internal splines, minimizing wear and noise, while also reducing weight to an impressive 329g with the spider and power meter. The Clavicula SE redefines crank design and sets a new industry benchmark.
 BCD 110 mm 130 mm
 Weight ~320g ~329g
 Spindle Diameter 30 mm
 Q-Factor 148 mm
 Chainline 43.5 mm
 Crank Lengths 170 mm / 172.5 mm / 175 mm
 Rider Weight Limit 110kg (243 lbs)
 Waterproofing IP 67*
 Finish 3k Twill - Matte or Gloss
*100% protected against solid objects like dust and sand, and it has been tested to work for at least 30 minutes while under 15cm to 1m of water
_______________________: _______________________________
Sensor Position: • Integrated into Spindle (measures left side)
Measures: • Power / Cadence / Torque / Pedal Smoothness (Left)
Accuracy: • +/- 2 %
Power Range: • 0 W - 1999 W
Connectivity: • ANT+ or Bluetooth compatible bike computer or smartphone
Manufacturer Module: • SENSITIVUS Gauge
App: • Team ZWATT Power Meter
Firmware: • Firmware updates via App
Battery: • Integrated Rechargeable Li-ion Battery
Runtime: • 150 hrs.
Waterproofing: • Integrate
