THM Clavicula SE Carbon Crankset
$1,599.00
* Unit price: $1,385.00 /
Article number: 30-03-00
THM's top-tier carbon crank, featuring an integrated carbon axle, is a remarkable engineering feat. Extensive development focused on optimizing geometry and structure, resulting in unparalleled stiffness across all planes, ensuring efficient power transmission. A patented carbon-to-carbon interface between the left-hand crank and axle sets new industry standards, reducing wear and noise while being exceptionally lightweight at 293g with the spider.
Notably, THM introduces an innovative power meter, revolutionizing crank design and setting a new benchmark for performance and precision in the cycling world.
 BCD 110 mm 130 mm
 Weight ~293g ~302g
 Spindle Diameter 30 mm
 Q-Factor 148 mm
 Chainline 43.5 mm
 Crank Lengths 170 mm / 172.5 mm / 175 mm
 Rider Weight Limit 110kg (243 lbs)
 Finish 3k Twill - Matte or Gloss
