Syntace 6-Bolt Rotor Shim Set
SKU:
EB00B8F1
$10.99
Syntace Disc Brake Shims are ideal for riders with multiple wheelsets who want to eliminate the need to adjust caliper position when swapping wheels. These stainless steel shims are also useful to compensate for frames or hubs that are out of spec with the rotor too far inboard or the caliper too far outboard. Unlike other rotor shims, these are a single piece for all six rotor bolts making for quick and easy installation. These shim sets are sold in 8 pieces of .2mm thick shims and are made to fit standard 6-bolt ISO brake rotor mounts.
Weight0.8 grams per shim
Materialstainless steel
Compatibility6-Bolt ISO hubs and rotors
Adapters
Brake Parts
Fits:
6 Bolt
Stainless Steel
