Supacaz Fly Cage Bottle Cage
$25.00 - $50.00
Supacaz Fly Cage bottle cages are the perfect way to add a bit of extra "pop" to your bicycle.  Each Fly Cage is meticulously manufactured from aluminum, color is then applied through either anodizing or hand painting (depending on model), and as a final touch, each cage is adorned with a small laser-etched logo.  While the aluminum construction keeps weights low (weights start at 18 grams each), these cages are approved for both road and mountain bike applications; the cage "wings" keep bottles locked down tight while also remaining highly accessible.  Available with either anodized or hand-painted finishes (hand painted finishes are extremely limited), in single colors as well as color combinations , the Fly Cages are the perfect accessory to make sure your bottles stay locked in while simultaneously adding a unique aesthetic touch to your bike.
Cage Weight, Anodized Aluminum18 grams
Cage Weight, Limited Edition Hand Painted Aluminum20 grams
Cage Weight, Oil Slick Anodized23 grams
Cage MaterialAluminum
Bottle Cages
Brand:
Supacaz
Aluminum
