SRAM Etap AXS shifting is compatible with cassettes up to a maximum range of 10-33.
The SRAM RED eTap AXS Electronic system is an intuitive, high performance wireless groupset. At the core of this drivetrain is AXS - the electronic integration platform that allows you to easily personalize the groupset right from your phone and enable your choices while riding. Orbit chain management provides a reassuringly quiet, secure and smooth ride, whatever the terrain.
HRD SHIFT-BRAKE SYSTEM
Fully wireless electronic shifting. Fully hydraulic disc braking. The SRAM RED eTap AXS™ HRD shift-brake system is the future. And the future is custom. AXS™ enabled and easily personalized for hand size and reach, this is the best shifting and braking experience—for all riders
SHIFT-BRAKE SYSTEM
The same great eTap® shift logic, updated with the connectivity of AXS™. The RED eTap® shift-brake levers build on the original eTap® foundation while integrating their newest technologies. And it’s easily personalized, from shifting sequences to reach.
FRONT DERAILLEUR
The SRAM RED eTap AXS™ front derailleur leverages our advancements with X-Range™ gearing. The derailleur design carves out space for wide rear-tire clearance, making it a perfect fit for modern riding. And the shifting is quick and precise.
REAR DERAILLEUR
The heart of the connected cadre. The SRAM RED eTap AXS™ rear derailleur is AXS™ enabled for easy personalization and designed for both 1x and 2x systems. Advanced chain management keeps it silent and secure no matter the terrain. The derailleur also comes with faster pulleys, bearings, motors and signals, improving speed in every way.
2x HRD | Hyd Shift/Brake Levers Front/Rear Derailleurs and Batteries Disc Cailpers w/Flat mount adapter 2x - 160mm 6-bolt Rotors Charger USB Stick and Quick Start Guide | 1497g |
1x HRD | Hyd Shift/Brake Levers Rear Derailleur and Battery Disc Cailpers w/Flat mount adapter 2x - 160mm 6-bolt Rotors Charger USB Stick and Quick Start Guide | 1343g |
2x Rim Brake Kit | Shift/Brake Levers Front/Rear Derailleurs and Batteries Charger USB Stick and Quick Start Guide | 936g |
1x Rim Brake Kit | Shift/Brake Levers Rear Derailleur and Battery Charger USB Stick and Quick Start Guide | 763g |
Hydraulic Brake Shifters | 248g ea. approx.(fluid) | |
Rim Brake Shifters | 143g. ea. | |
Front Derailleur w/battery | 168g. | |
Rear Derailleur w/battery | 300g. | |
Front/Rear Hydraulic Caliper | 175g. approx.(fluid) | |
160mm 6-bolt Rotors | 125g. each | |
Max Cog Size | 33T |
