Sram Flat Mount Disc Brake Adapter
$23.00
Getting your rotor sizes dialed in for whatever terrain you are aiming to tackle is an important factor in optimizing your road disc set-up.  These SRAM Flat Mount Adapter Kits provide the needed interface between SRAM flat mount disc calipers and the flat mounts on the frame.  The 0/20mm front option allows both the use of 160mm and 140mm rotors, while the rear option is for 160mm rotors.  Each kit includes a anodized black aluminum bracket along with stainless steel hardware.
If you have any questions on compatibility, please don’t hesitate to contact us.
Weight (Front 140/160)23 grams
Weight (Rear 160)13 grams
Frame CompatibilityFlat Mount
Caliper CompatibilitySRAM Flat Mount
Material (Adapter Bracket)Aluminum
Material (Hardware)Stainless Steel
Adapters
Size:
140mm
Size:
160mm
Fits:
Flat Mount
Style:
Road Disc
Aluminum
