$78.00
Article number: 001-04-01
CenterLine X rotors are the lighter weight version of SRAM's quiet, smooth, and robust CenterLine rotors. The CenterLine X rotor features a two-piece design with an alloy center and steel brake track. Rounded edges make for easier wheel installs and are UCI-compliant.
  • Lightweight, two-piece design
  • Rounded edges are UCI-compliant and allow for easier wheel installs
  • Compatible with both road and mountain bike brakes
 Diam (Rotor) 140mm, 160mm, 180mm
 Color (RT) n/a
 Bolt Material (RT) n/a, Steel, Titanium
 Hub Interface 6 Bolt, Centerlock
 Rotor Type Centerline 2-Piece
 Rec Lockring Lockring sold separately, n/a
