Disc Brake Rotor Shim
$5.00
Precision-engineered disc brake rotor shims, crafted from durable stainless steel at 0.2 mm thickness, ensure perfect rotor alignment for seamless wheelset changes without repeated brake caliper adjustments. Compatible with Centerlock or 6-bolt hub configurations, they offer a unique solution for optimal brake performance. Available individually or in packs of 5, these shims are essential for cyclists aiming to streamline their setups. Manufactured by BSC Tools and SRAM, exemplifying their commitment to high-quality, innovative cycling solutions.
 Thickness 0.2 mm
 Material Stainless Steel
