Specialized Turbo Pro Tire
Article number: | 006-06-03 |
The Turbo Pro tire is a competitive clincher that utilizes many of the same features found in the S-Works version. After all, competitive riders need a fast, light, and tough tire, and the Turbo Pro is all three. With its flawless tread, supple casing, and unrivaled GRIPTON® compound, it features extremely low rolling resistance and superior cornering traction. Put it all together, and you'll be climbing and descending with confidence and speed.
Compound | GRIPTON® | |
Flat Protection | Blackbelt | |
Casing | 60TPI | |
Weight | Recommended Tire Pressure | |
700x24 | 200 grams | PSI 100-125 |
700x26 | 220 grams | PSI 100-125 |
700x28 | 240 grams | PSI 85-95 |
