Specialized Turbo Pro Tire
$50.00
Article number: 010-06-03
Availability: In stock (1)
The Turbo Pro tire is a competitive clincher that utilizes many of the same features found in the S-Works version. After all, competitive riders need a fast, light, and tough tire, and the Turbo Pro is all three. With its flawless tread, supple casing, and unrivaled GRIPTON® compound, it features extremely low rolling resistance and superior cornering traction. Put it all together, and you'll be climbing and descending with confidence and speed.
 Compound GRIPTON®
 Flat Protection Blackbelt
 Casing 60TPI
  Weight Recommended Tire Pressure
 700x24 200 grams PSI 100-125
 700x26 220 grams PSI 100-125
 700x28 240 grams PSI 85-95
