The Specialized GRIPTON compound is the finest tire on the market. Combined with ultra-supple 320 TPI cotton casing, you get a unique tire that's very special—you get the Turbo Cotton tire. Dedicated to building the world's fastest tires from quality materials. The combination of these materials created the best clincher tire available. It provides a distinct performance advantage.
Rim Compatability | 700c Foldable Clincher | ||||
Compound | GRIPTON | ||||
Flat Protection | Blackbelt | ||||
Casing | 320 TPI Polycotton | ||||
Pressure & Weight | 700 x 24mm 700 x 26mm 700 x 28mm | PSI 115-125 PSI 95-115 PSI 85-95 | approximate weight 220g approximate weight 240g approximate weight 260g |
