Specialized S-Works Turbo Road Tubeless Tire
$90.00
The S-Works Turbo Road Tubeless tire gives ultimate in tubeless performance. It features low rolling resistance, while serving as a lighter weight option than other leading clincher/tube combos available. The GRIPTON compound means that you'll experience excellent cornering traction, while expending less energy on climbs and going significantly faster on descents.
Rim Compatability700c Foldable Tubeless
CompoundGRIPTON
Flat ProtectionBlackbelt
Casing180 TPI
Pressure & Weight 700 x 24mm
700 x 26mm
PSI 90-115approximate weight 240g
approximate weight 280g
Tubeless Tires
Road Tires
Size:
700x24
Size:
700x26
