Recommended sealant amount per tire: Tire size 24-26mm - 40ml 28-30mm - 50ml For Maximum performance, use 60ml for any 24-30mm
Rim Compatability | 700c Foldable Tubeless Ready | |
Compound | GRIPTON® | |
Flat Protection | Blackbelt | |
Casing | 120 TPI | |
- Pressure & Weight - | ||
700 x 26mm | ~ 260g | PSI 85-100 |
700 x 28mm | ~ 290g | PSI 80-95 |
700 x 28mm | ~ 310g | PSI 45-65 |
- RECOMMENDED SEALANT PER TIRE - | ||
24-26mm - 40ml | For Max performance | 60ml for any 24-30mm tire |
28-30mm - 50ml |
