Specialized S-Works Power Arc Saddle
$300.00
The Specialized S-Works Power Arc saddle expands on their original S-Works Power saddle, while keeping the same channel and length as the original. It's has a stiff, FACT carbon fiber shell and rails and lightweight EVA padding. There is plenty sit bone support, and it has been pairedi with a shorter-than-usual nose section to keep pressure off of soft tissue while riding in aggressive positions. This idea took a step further with an extra wide and elongated Body Geometry channel that's been proven through blood flow testing and pressure mapping to reduced numbness and pressure on unwanted areas.
Power loyalist design features a curved Body Geometry shape that better contours to your body. This gives more comfort  and superior performance in all seated positions, whether you're a man or woman.
WeightSize 143mm / Weight: 141g Size 155mm / Weight: 145g
Upper MaterialsCarbon fiber shell with Level 2 padding
Rail MaterialsCarbon fiber
Width143mm, 155mm
Length240mm
Rail SizeOversized 7x9mm
Saddles
Size:
143mm
Size:
155mm
Carbon
