Specialized S-Works Phenom Saddle
$300.00
The S-Works Phenom from Specialized is their flagship off-road saddle, fitted with a lightweight carbon shell and ovalized carbon rails for the best possible performance and strength at a low overall weight. The SW Phenom's lab-tested design includes race-tuned stiffness, with Specialized's Body Geometry design employing a center relief channel and medium density foam to ensure comfort on even the longest rides. Anti-snag nose and tail features, combined with low-friction panels on the saddle cover allow for quick and efficient positioning.
  • SWAT™-compatible mounts molded into the saddle base allow for sleek and integrated storage solutions
  • Super-light, EVA padding with medium density foam for comfort and support
  • Not compatible with side load clamping seatposts meant for 7mm round rails
  • Shaved ~15 grams from previous version
The S-Works Phenom saddle is available in two width options to fit a wide range of riders.
Weight, 143mm~149 grams
Weight, 155mm~152 grams
Upper MaterialSpecialized "level 2" padding
Rail MaterialFACT carbon fiber
Rail Size7x9 oval
Saddles
Size:
143mm
Size:
155mm
Carbon
