Specialized Roubaix Pro 2BR Tire
$45.00
Article number: 010-06-04
The Roubaix Pro 2Bliss Ready is an endurance road tire that's well suited for smooth and rough roads alike. That's because it's fast like any competitive road tire, only it features a unique Endurant casing with bead-to-bead puncture protection and increased sidewall stability. The casing smooths your ride and keeps you fresh, while the tread handles responsively. Add to this the lower pressures and natural pinch-flat protection that tubeless setups provide, and you'll be hammering through corners confidently in no time.
 Compound GRIPTON®
 Flat Protection Endurant Casing and Black Belt
 Casing 120 TPI
  Weight Recommended Tire Pressure
 700x30mm/32mm 375 grams PSI 45-90
