The Roubaix Pro 2BR is a 2Bliss Ready endurance road tire can be used on smooth and rough roads alike. A fast competitive road tire that features a unique Endurant casing with bead-to-bead puncture protection. The casing smooths your ride while the tread handles responsively. Add to this the lower pressures and natural pinch-flat protection that tubeless setups provide, and you'll be shredding through corners confidently in no time.
The Roubaix Pro 2BR tire is available with black or transparent (brown) sidewalls
The 700 x 30mm/32mm should only be used on Hooked type rims and not Straight-Side (hookless) type rims.
Rim Compatability | 700c Foldable Clincher / Tubeless | |
Compound | GRIPTON | |
Flat Protection | BlackBelt | |
Casing | 120 TPI | |
Pressure & Weight | 700 x 30mm/32mm --- PSI 45-90 --- approximate weight 375g | |
